Discussion topic: No power on main box
This message was authored by: Jo005
I have no power on the main box. It won't switch on.
Re: No power on main box
Red / amber light not showing?
Avatar for Jo005
Level 0 icon
I have no power on the main box. It won't switch on. I need an engineer as I am not happy to do myself
Well there's nothing you can do, it's broken and will need replacing. Quickest option is a box swap delivered. There are normally only 4 cables to connect (2 satellite feed, 1 power, 1 HDMI) and you have to make sure you keep your viewing card. Note: there are two types of power cords for different variants of these Q boxes. One with an external power brick and one without. Make sure the replacement box matches or if not, that you also swap the power cable.
a wait for an engineer will take a lot longer I suspect
anyway, start here https://www.sky.com/help/articles/sky-box-problems
