Discussion topic: No picture.
Message posted on 30 May 2023 06:20 PM
No picture.
Have rebooted router, changed HDMI lead, switched everything on and off several times but sky box notconnecting with tv. tv is ok as we can get netflix, amazon fire etc.
Message posted on 30 May 2023 06:21 PM - last edited: 30 May 2023 06:23 PM
Re: No picture.
@CaffyL What does the TV display when you select the HDMI input for the Sky Q box? Have you tried cycling through the TV inputs?
Message posted on 30 May 2023 06:22 PM
Re: No picture.
Message posted on 30 May 2023 06:32 PM
Re: No picture.
Cycled through the sources many times but no picture. Just a blank screen
Message posted on 30 May 2023 06:34 PM
Re: No picture.
@nigea999 thanks for the idea. just tried this several times but just a blank screen
Message posted on 30 May 2023 06:41 PM
Re: No picture.
@CaffyL Are you able to try another HDMI cable or change the cables input to another HDMI socket?
Is the cable securely seated in the back of the box & also the TV?
Message posted on 30 May 2023 06:45 PM
Re: No picture.
@GD1 - thanks but have changed HDMI lead and tried all three sockets
Message posted on 30 May 2023 06:47 PM
Re: No picture.
Have removed HDMI cable both ends and reseate several times. Also removed and swapped and re-swapped the two external input cables
