Discussion topic: No power lead for sky q 2tb
This message was authored by: MMed
No leads in the box or remote control
Re: No power lead for sky q 2tb
@MMed  You'll need to provide some more info than you have.
Is this a new install?  Is this a replacement box?
Avatar for MMed
It was a replacement box.
@MMed  Do you not have the cables & remote from the old box?
Avatar for MMed
I got a hdmi but the power port is different.
@MMed  I would give Sky a call.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
