Discussion topic: No picture on the TV
Message posted on 31 May 2024 03:33 PM
There is no picture
Message posted on 31 May 2024 03:53 PM
Re: No picture on the TV
@Ian2020 wrote:
There is no picture
Hi @Ian2020
Is the front right LED on the Q box Green or Amber.
If it is Amber have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
If it is Green
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
