15
This discussion topic has been answered Discussion topic: No network connection
This message was authored by: Salanya
Re: No network connection
@Salanya wrote:
I did all of this and still not connect
Hi @Salanya
Did you carry out a network reset as follows:-
Note that you can only use WPS if you are on Sky Broadband with Sky Q router.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Avatar for Salanya
Avatar for Salanya
Hi @Salanya
Avatar for Salanya
@oldfella thank you I will try that 👍🏼
This message was authored by: Woodsy
I have done reset using wps. Still no connection
This message was authored by: Patel30
I did all resets and still don't work
This message was authored by: Kim63
I have switched everything off three times and reset router still no network connection or skygo or skyq mini box
Avatar for Salanya
We had to hold down the reset button on sky box for 30 seconds and then waited to reset and it worked
This message was authored by: mary+duthie
I have tried everything
Did all that still not working
I've escalated this. Watch out for a blue chat bubble.
@Chodley   I still can't get connected to my network and I can't watch my sky in the other room I have tried all the advice the is on the system nothing Works
This message was authored by: Greenfingers001
Thanks for escalating this. We’ve sent @mary+duthie an invite to chat.
That's why I escalated it
