This discussion topic has been answered Discussion topic: No network connection
Message posted on 09 Jul 2023 10:24 AM
Message posted on 09 Jul 2023 10:58 AM
@Salanya wrote:
I did all of this and still not connect
Hi @Salanya
Did you carry out a network reset as follows:-
Note that you can only use WPS if you are on Sky Broadband with Sky Q router.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Re: No network connection
Message posted on 09 Jul 2023 10:25 AM
Hi @Salanya
Message posted on 09 Jul 2023 11:39 AM
@oldfella thank you I will try that 👍🏼
Message posted on 24 Aug 2023 07:27 PM
I have done reset using wps. Still no connection
Message posted on 20 Sep 2023 04:36 PM
I did all resets and still don't work
Message posted on 20 Sep 2023 09:45 PM
I have switched everything off three times and reset router still no network connection or skygo or skyq mini box
Message posted on 20 Sep 2023 10:38 PM
We had to hold down the reset button on sky box for 30 seconds and then waited to reset and it worked
Message posted on 20 Sep 2023 10:39 PM
I have tried everything
Message posted on 20 Sep 2023 11:17 PM
Did all that still not working
Message posted on 21 Sep 2023 07:26 AM
@mary+duthie wrote:Did all that still not working
I've escalated this. Watch out for a blue chat bubble.
Message posted on 21 Sep 2023 08:38 AM
@Chodley I still can't get connected to my network and I can't watch my sky in the other room I have tried all the advice the is on the system nothing Works
Message posted on 21 Sep 2023 11:25 AM
Thanks for escalating this. We’ve sent @mary+duthie an invite to chat.
Message posted on 21 Sep 2023 04:38 PM
@mary+duthie wrote:@Chodley I still can't get connected to my network and I can't watch my sky in the other room I have tried all the advice the is on the system nothing Works
That's why I escalated it
