This discussion topic has been answered Discussion topic: No network connection
Message posted on 25 Jun 2023 02:22 PM
No network connection ( tv/ iPad) but good satellite signal. Rebooting router has not helped
Message posted on 25 Jun 2023 02:25 PM
Hi @Sue+Sloan
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Hi @Sue+Sloan
Message posted on 23 Sep 2023 08:15 PM
Re: No network connection
I've done everything that was said to do ie press the button on the back of my router,that didn't work. I can't watch Netflix or any other apps plus I can't go onto my account
Message posted on 19 Jan 2024 03:39 PM
I'm having exactly the same issues. Strong braodband but no network connection. Turning off/on and/or resetting via the WPS button does not help. Sporadic problem as it might be alright for a few days then not, can't access APP programs just TV channels/recordings.
Can't get to any point on line to request an engineer - just get sent back to 'press the WPS button'!!
Message posted on 29 Jun 2024 09:57 AM
No network
Message posted on 29 Jun 2024 10:05 AM
- No network
