Discussion topic: No multi room connection
This message was authored by: Svenart
No internet connection on minor box
Re: No multi room connection
@Svenart Have you tried rebooting your main Q box ie
then
reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Svenart
If a reboot doesn't help try a Network Reset on the mini.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
