Discussion topic: No internet connection0
This message was authored by: Molly89
Set up new router. No Internet connection to my satellite TV.  I've tried everthing. Going to reconnect old router if I can get no help as I can't get my apps up on TV.
Re: No internet connection0
@Molly89
Presumably you have Sky Q so I'll move your post as it's not a Sky Accessibility issue.
Hi @Molly89
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky or Sky Max router) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
