Discussion topic: No internet connection
Message posted on 16 Mar 2025 11:14 AM
I'm having a real problem connecting my SkyQ box to my wifi. Over the last few days I've been unable to reconnect my wifi to the skybox. It keeps telling me that I have no internet connection. All other devices in the home are connected to wifi with no problem accessing the internet.
I've gone through all the troubleshooting guides a number of times, but it's still not connecting. I have also tried hard wiring the box to an ethernet cable, and although it then says that it's connected to my router, - how can it not be! - It still doesn't connect to the outside world.
It doesn't help that I've forgotten the password to access the wifi, and can't find anywhere as to how to reset it to what I want.
I've done a complete reset and it still doesn't connect. I'm wondering now whether the wifi radio has packed up.
Any help would be good.
Message posted on 16 Mar 2025 11:23 AM
Re: No internet connection
Hi @SteveC528
Assume you tried resetting the WiFi as follows:-
if you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band..
You WiFi password if you haven't changed it will be shown on your router.
Message posted on 16 Mar 2025 11:54 AM
Thanks Oldfella.
You're right, I have done all of the above. I have a non-sky router with 3rd party supplier. I'm not sure what happened to change everything. It's been working fine for the past few years !!!!
