Discussion topic: No internet connection
Message posted on 01 Aug 2023 11:10 AM
Message posted on 01 Aug 2023 11:13 AM
Re: No internet connection
@Mcgregor7 wrote:
I have had no internet connection, tried restarting etc, with no luck
Hi @Mcgregor7
Assume this is on your main Q box.
Have you carried out a Network reset on the Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
