Discussion topic: No internet connection
This message was authored by: Mcgregor7
I have had no internet connection, tried restarting etc, with no luck
Re: No internet connection
Hi @Mcgregor7
Assume this is on your main Q box.
Have you carried out a Network reset on the Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
