Discussion topic: No finding sky Q box on the network
This message was authored by: Kerry1512
No sky Q box on the network
This message was authored by: Stephen+Mourton
Re: No finding sky Q box on the network
@Kerry1512   Sorry could you expand on that I'm not sure what you are saying or wanting.  Thanks.
@Kerry1512 try rebooting your router
then
reboot your main Q box ie
finally if you have any mini boxes reboot them
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
