3
This discussion topic has been answered Discussion topic: No connection
This message was authored by: jellytot72
No connection
Help I've reset router and box. Still no network connection !!
Re: No connection
Hi @jellytot72
Assume this is your main Q box.
Have you carried out a Network reset on the Q box.Try a Network Reset found in Q box Home - Settings - Setup - Network.
Re: No connection
Hi @jellytot72
Avatar for jellytot72
Re: No connection
Thank you. I'm all sorted
This message was authored by: Russ4938
Re: No connection
Ours went down last night similar scenario to several months back. No voice, no BB!
Status said nothing wrong nor did there testing facility however, it's coming back as failed locally now!
(removed)
Moderator note: Removed inappropriate language
