Discussion topic: No connection with my multi screen
This message was authored by: PeterReid
Message posted on 30 Nov 2023 05:11 PM
No response from my remote to multi screen device
Find out more
Message posted on 30 Nov 2023 05:39 PM
Re: No connection with my multi screen
@PeterReid if the mini box is not furning on try pressing the amber light to see if it turns on if it does follow the steps below to repaire your remote
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
