This discussion topic has been answered Discussion topic: Sky q mini has not found paramount plus even though it is part of sky cinema package on main sky q
Message posted on 30 Nov 2023 03:50 PM
I have added a sky q mini today, updated the software and set up the remote but when I call for Paramount Plus it requires my log in details for Paramount. My Paramount comes as part of my Sky package and works fine on main Sky q and as far as I can recall I don't have a separate login for Paramount.
I notice that others have had this problem but were taken to a one to one with sky which means I could not see their solution.
Message posted on 30 Nov 2023 04:59 PM
@Chas3 you would have had to create a username and password to log in to paramount + so you would have to try and remember what you used so you can log into paramount+ on your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 30 Nov 2023 05:52 PM
Re: Sky q mini has not found paramount plus even though it is part of sky cinema package on main sky
You are correct although I didn't believe it before posting. I found the login after your reply and problem solved.
Message posted on 30 Nov 2023 05:53 PM
@Chas3 glad you are all sorted 😀
