Discussion topic: No connection to mini boxes
This message was authored by: Dun2
There is no satellite signal to either of my mini boxes since yesterday morning. I have followed instructions to check connections throughout this time but to no avail.
Re: No connection to mini boxes
Hi @Dun2
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
