10 Oct 2024 09:02 PM
10 Oct 2024 09:05 PM
@Fimb073 wrote:
Our sky Q box is connected to the router but not to the internet. We have reset sky q box and sky router but nothing is working. Also won't connect with WPS button or WiFi password
Hi @Fimb073
10 Oct 2024 09:18 PM
Done all that and it is still not working!
10 Oct 2024 09:30 PM
Posted by a Superuser, not a Sky employee. Find out moreWho is your broadband supplier @Fimb073
10 Oct 2024 09:31 PM
We have the same problem - think it's The Q box that hs failed. Too late now to ring Sky
10 Oct 2024 09:39 PM
10 Oct 2024 09:51 PM
My sky q box keeps losing Internet connection I am a bt fiber user. Everything else is connected with no issues.
My speed is very good
11 Oct 2024 09:28 AM
Its Sky!
