Discussion topic: No conection to QBox mini
Message posted on 07 May 2024 04:38 PM
Sky engineer disconnected qbox mini but now cannot connect to it.
Message posted on 07 May 2024 05:19 PM
Re: No conection to QBox mini
@Ang17When you say he disconnected it do you mean he replaced it?
Message posted on 07 May 2024 05:22 PM
Hi @Ang17
Reboot the mini as above.
Message posted on 07 May 2024 08:00 PM
Cheers Oldboy, will give it ago.
