Discussion topic: I need a new sky box with Bluetooth pls
Message posted on 07 May 2024 07:15 PM
I need a sky box with blue tooth so I can have behind my new tv
Message posted on 07 May 2024 07:21 PM - last edited: 07 May 2024 07:22 PM
Re: I need a new sky box with Bluetooth pls
if you are referring to the remote connecting to bluetooth then all boxes are bluetooth.
Is your box an old mini box with an old remote, some old remotes were not bluetooth.
You can tell if the remote is bluetooth as they have a voice button either on the front or side
If you have a coice enabled remote then maybe it just needs pairing wit hthe box : in which case may I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
