Discussion topic: No bbc1 but other bbc channels are fine
This message was authored by: Onesmus
Cannot get bbc1 but bbc2, 3 and 4 are ok
Re: No bbc1 but other bbc channels are fine
@Onesmus
What are you seeing when you try to view channel 101? Any error message displayed?
Avatar for Onesmus
Just a a picture with No Signal,  below it is txt saying broadcaster signal failure. I find it strange because channels 102 and bbc3 and 4 are fine.
@Onesmus
If a message is displaying ”No signal” it tends to be from your TV (in which case check the HDMI cable between the Sky Q box and your TV).
Any “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
