Discussion topic: No access to sky cinema
Message posted on 30 Nov 2025 02:14 AM
I have a sky cinema subscription but sky wont allow me to access it
it's telling me to
uograde for it?!?!?
help!!!
Message posted on 30 Nov 2025 10:53 AM
Re: No access to sky cinema
it's telling me to
uograde for it?!?!?
help!!!
Hi @ninamold
Have you tried rebooting your Q box?
Failing this,
