Discussion topic: No WiFi connection on mini
Message posted on 11 Mar 2025 06:55 PM
Hi my mini box stopped working keeps saying no WiFi connection it worked on 1st setup then stopped working
any advise would be helpful
Message posted on 11 Mar 2025 07:41 PM
Re: No WiFi connection on mini
Hi @Royccc
Reboot the mini as above.
Message posted on 13 Jul 2025 09:16 PM
Hi iam still NOT using my multi room Tv would it be possible to cancel this please as iam paying for something iam NOT USING please bare in mind I have been with sky a long time and I would appreciate if you can cancel this
Message posted on 14 Jul 2025 08:56 AM
@Royccc wrote:Hi iam still NOT using my multi room Tv would it be possible to cancel this please as iam paying for something iam NOT USING please bare in mind I have been with sky a long time and I would appreciate if you can cancel this
You'll need to call Sky to do that
