6
Discussion topic: No Sky Q Satellite Signal - Communal Dish
This message was authored by JamieMcA88 This message was authored by: JamieMcA88
I have just moved into a new flat (communal dish) and the Sky Q set up is different from my previous house. There is only 1 sat cable and there is a powered unit as in the images. Try as I may I cannot get a signal. The previous tenant (also had SkyQ)
said that you have to power on the switching device and then reattach the sat 1 cable. Nothing is happening 🤦‍♂️
Anyone able to help? Engineer is not due out until 18th May.
This message was authored by Laing1 This message was authored by: Laing1 Answer
Re: No Sky Q Satellite Signal - Communal Dish
@JamieMcA88 did you have your own dish at your previous address if so then you will need to go into the hidden menu and change the LNB type from wideband to SCR
To enter the engineers menu do the follow
press the home button then scroll down to setting sand hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
once in there in set up you will find the LNB option
