Discussion topic: No Satellite Signal
This message was authored by: FATBOYSFATARMY
No Satellite Signal
Loss of Signal / Intermittent signal since last Wednesday
Followed the troubleshooting guide, issue is still intermittent, now no signal
Signal can be lost for 2 mins, Hours or even a full evening usually happens after watching Sky with no issues for a good few hours.
Re: No Satellite Signal
If a message is displaying ”No signal” it tends to be from your TV not being on the correct input (check the HDMI cable between the Sky Q box and your TV)
Any “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
Avatar for FATBOYSFATARMY
Level 0 icon
Tried the connections all appear good
As stated its the Satellite signal, My guess now it's either the box or the dish is not aligned up.
Unsure why I would be able to watch tv with no issues for hours then lose signal though.
