This discussion topic has been answered Discussion topic: No Satellite Signal
Message posted on 13 Aug 2025 08:38 PM
I am in a residential home with my own Satellite dish. Since yesterday, I have no satellite signal as per my Sky Q box.
I checked my dish and no obvious issues. Tried powering off sky box at mains and checked cables. All seems fine but issue with no satellite signal still persists.
Can you help or does an engineer need to call to resolve?
Message posted on 13 Aug 2025 08:45 PM - last edited: 13 Aug 2025 08:46 PM
@Mwalsh36
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
@Mwalsh36
Message posted on 13 Aug 2025 11:51 PM
No satellite signal
Message posted on 14 Aug 2025 04:59 AM
Re: No satellite signal
You seem to have asked the exact same question that @Mwalsh36 did an hour or so earlier with the same terminology. Are you @Mwalsh36 using a different log in name?
I have merged your posts as the advice remains the same as above,
Message posted on 14 Aug 2025 10:38 AM
Try again
No I'm not that other person at all. I used the start of his message as so similar and then added my personal comments. I've booked an engineer now as got nowhere myself or online. Same person, really!!
Message posted on 14 Aug 2025 04:10 PM
Engineer came today and changed the dish, which was badly corroded after 9 years, as house is near the coast.
Message posted on 14 Aug 2025 04:27 PM
Great news. That's excellent service to get an engineer out the next day.
Message posted on 15 Aug 2025 06:42 AM
So inside 24hours they replaced something for free, including labour, which is officially your property.
Maybe that's why you stay with Sky 😉
