This discussion topic has been answered Discussion topic: No Satalite Signal
Message posted on 12 Mar 2023 06:17 PM
Hi
My tv in the kitchen is saying No satellite signal. Unplugged mini Q box and tv also unplugged booster mini box. Still showing no satalite signal. All the relevant lights are on just can't understand why it's not working. Never had this problem before with the tv in the kitchen. . Obviously the main Q box in the lounge is fine no problem there. Any advice would be much appreciated. Thank You
Message posted on 13 Mar 2023 10:05 AM
Hi @orchard22
On your Main Q box can you go to Settings, then scroll down to Watch on Sky Q Mini Box and select Reactivate.
This will refresh the signal going to the Mini Box.
Let me know how you get on and we can help you further if required.
Tom
Message posted on 12 Mar 2023 07:07 PM
Re: No Satalite Signal
@orchard22 wrote:
Hi
Hi @orchard22
First try rebooting the main Q box and then when this is completely back up and running reboot the booster and then the mini.
Reboot the booster and when this back up and running reboot the mini as above.
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with booster
You will be asked to press the WPS button on the booster (not the mini).
Hi @orchard22
Tom
