Discussion topic: No Connection & not able to reset by holding WPS button down
Message posted on 17 Aug 2023 08:48 PM
I have 'No Network Connection' on my TV despite the fact that my Sky Wifi is working just fine. I have tried resetting it by holding down the WPS button on the Sky Q router however it is not working (it has worked successfully in the past however not working now).
Please help
Message posted on 17 Aug 2023 08:58 PM
Re: No Connection & not able to reset by holding WPS button down
Please help
Hi @hackneykp
Are you carrying out the following procedure?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
On Sky broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
You have 2 minutes after carrying out the Network to press WPS button on the router.
Message posted on 17 Aug 2023 09:09 PM
Thank you for your help. I dont have a WPS button on my Wifi router. I only have one on my Sky Q router.
Yes I have followed these instructions (pressing the WPS on the Sky Q) with no luck sadly. Its an ongoing issue.....
Message posted on 17 Aug 2023 09:14 PM
@hackneykp If it's sky hub then you do have a WPS button, if it's the larger upright hub the wps button is on the right hand side as you look at the front.
Message posted on 17 Aug 2023 09:21 PM
Hi @hackneykp
If you are on Sky Broadband then your Sky router has a WPS button.
See below.
Revisit my. Earlier post and carry out the Network reset on the main Q box.
'Press the WPS on the Sky Q broadband router not the Q box.
Message posted on 17 Oct 2023 09:32 AM
You cannot reset the network settings unless you are connected to a network - it will not give you the option in the menu - I have connected to another hotspot and reset the defaut settings - this looks to be a router issue
I have had exactly the same issue and have worked this through as far as I can go now (network and electroic product engineer) - something appears to have changed or failed for many people at similar times
Message posted on 11 Nov 2023 07:24 PM
Very same thing as me. I've been trying for days and it keeps saying unsuccessful connection. We only change to Q Sky few weeks ago. It's the worst thing we ever did. We regret it big time.
try ring sky so hard to talk to a physical person. 😢
Message posted on 11 Nov 2023 07:50 PM
Who is your Broadband supplier @Peadarowens ?
Message posted on 11 Dec 2023 08:41 PM
I've had the same issue for two weeks now. I'm glad I'm not the only one. We've been with Sky for 15+ years, I'll eventually be cancelling my subscription with them. The service has gone from bad to horrid over the past couple of years.
Message posted on 26 Jan 2025 09:10 PM
We are now having the same problem!
Message posted on 26 Jan 2025 09:58 PM
@MarkhamJ wrote:We are now having the same problem!
Which one?
This thread is one of hundreds about wifi connection problems and has some random wps stuff in it which doesn't make a lot of sense.
Message posted on 15 Apr 2025 09:41 AM
I have a fix for this issue.
Log in to your hubs GUI ( 192.168.0.1 )
Enter user name ( admin )
Enter password ( same as your hub password )
In the WiFi Tab, look down to Security Options Change to the fourth option
Save
The connect Sky Q box with WPS 👍👍
Message posted on 15 Apr 2025 12:19 PM
We have a new Sky Q box and a new Sky Router. The WiFi is up and running and we are connected through all our other devices, however, when I try and reset the Sky Q box to connect the search ends with "Search unsuccessful". I am pressing the WPS button while the search takes place and a green light flashes on the front of the router - still no connection. I have tried this process several times with no success - the router is in the same room as the Sky Q box so there shouldn't be any need for a booster. Very frustrating as this should be such a simple process with up to date and expensive technology.
Message posted on 15 Apr 2025 12:43 PM
@Phil7990 wrote:We have a new Sky Q box and a new Sky Router. The WiFi is up and running and we are connected through all our other devices, however, when I try and reset the Sky Q box to connect the search ends with "Search unsuccessful". I am pressing the WPS button while the search takes place and a green light flashes on the front of the router - still no connection. I have tried this process several times with no success - the router is in the same room as the Sky Q box so there shouldn't be any need for a booster. Very frustrating as this should be such a simple process with up to date and expensive technology.
Being in the same room, you'd be better off connecting your Sky Q to your router via direct ethernet cable.
Message posted on 15 Apr 2025 04:34 PM
@Phil7990 what router did Sky send you is it a black or white router
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
