Discussion topic: New tv and sky
This message was authored by Highways01 This message was authored by: Highways01
New tv and sky
Set up sky q to a new tv. When watching sky the tv screen keeps turning on and off. This only happens with sky
Re: New tv and sky
Check the HDMI cable is corrected fitted at both ends @Highways01
Try another cable if you have one.
Also try rebooting both the Q box and the Television set.
To reboot the Q box press Standby on your Sky Q remote (if the box responds to the remote), and then switch off and unplug at the mains.
To reboot the Television set,  disconnect the power lead for 30 secs and then reconnect.
