Discussion topic: Mini box no wifi connection and remote not working
This message was authored by: Simo1959
Message posted on 16 Nov 2024 03:19 PM
Mini box not working no wifi remote not working tried all options
Find out more
Message posted on 16 Nov 2024 04:01 PM
Re: Mini box no wifi connection and remote not working
Hi @Simo1959 Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on then
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
