Discussion topic: New sky Q box
This message was authored by: enna19490
New sky Q box
I have a new sky q box being delivered this week sometime
unfortunately I cannot disconnect the old one  -perhaps I need an engineer to come out to install it
Re: New sky Q box
Hi @enna19490   You need to contact Sky.
Re: New sky Q box
@enna19490
I don't think that is something that Sky will necessarily send an engineer to do especially if they've arranged a 'doorstep box swap' (remember to remove the viewing card from the current box).
Perhaps ask a family member, friend or neighbour to help if you're struggling.
Re: New sky Q box
Is it the screw caps in the satellite cables? They can be quite tight. A gentle grip with a pair of pliers usually does the trick, or sometimes just a tea-towel is enough to allow finger pressure to work with less pain!
