Discussion topic: New second sky mini box
This message was authored by: MIchaelWaite
I've just been sent a second Sky mini box which I'm setting up. Everything is connected even connected to the sky QB but still won't work comes back with. Please check your subscription titled you to view the channel on this box otherwise if you're using the box of first time please wait a few minutes I've left the 1015 minutes and it's still a blank screen. We are subscribed to have up to 4 boxes. Any ideas
Re: New second sky mini box
Hi @MIchaelWaite
Reboot the mini as above.
You could also try setting up the second mini by swapping it with the first to see if it will set up at this location.
