Discussion topic: Paramount + won’t work past sign in or get. Won’t accept my sign in
Message posted on 29 Dec 2023 04:51 PM
Just got new tv everything working except paramount +. Can only get the sign in or get.
wont accept my sign in and says my email or password is incorrect 🤷🏻♀️
Message posted on 29 Dec 2023 04:58 PM
Re: Paramount + won’t work past sign in or get. Won’t accept my sign in
Just to be sure, presumably you have signed up and paid for Paramount+?
If so have you another device, iPad etc and can you sign in on that? If so double check your login and password on that and check they are the same. Obvious I know, and you may have already done that but thought it worth suggesting.
Message posted on 29 Dec 2023 05:21 PM
I get paramount free with sky.
on old tv it worked fine. Sign in with sky id and password but now won't accept either
Message posted on 29 Dec 2023 05:50 PM
@newmans22 are you sure that it was your Sky ID and password you used to sign up for Paramount+ as you had to create an account and was asked for an email as your username and then a password
just a thought
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
