Discussion topic: New replacement sky q stuck
Message posted on 24 Dec 2025 10:52 PM
New sky sky Q box not working stuck in red.
Message posted on 25 Dec 2025 10:32 AM
Re: New replacement sky q stuck
Hi @Grape What happens if you press the power button on the box itself? To rule out a problem with the remote or it is not paired.
Message posted on 25 Dec 2025 11:27 AM
Hi @Grape
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Message posted on 25 Dec 2025 11:53 AM
Have you already tried powering it off at the wall?
