Discussion topic: Can't stream or download anything for the last couple of days. Download speed really low. Tried Appl
This message was authored by: ChrisD42
Download speed and streaming really slow. 23rd and 24th December. Is it just Xmas?
Have power cycled Sky Q and my broadband and tried to refresh apps.
Current broadband speed is 90Mb/s
Re: Can't stream or download anything for the last couple of days. Download speed really low. Tried
No it's not christmas. Sometimes the Q box wifi goes like this but a reboot usually resolves it (as long as the wifi connection is strong)
Hi @ChrisD42
Go into Netflix on the Q box and select the Get help  near the bottom of the left hand menu.
On the next screen select Check your network.
This will give you the Network speed your Q box is using.
