3
This discussion topic has been answered Discussion topic: New remote
This message was authored by: theglovers
New remote
Hi we had the engineer out today to solve our WiFi problem which hopefully is sorted, he mentioned we should get a up to date sky remote as we have the older one with the swirly bit in the middle, the engineer said if we contact you, you will send a new one out. Thanks in advance David
Re: New remote
Hi @theglovers
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
This message was authored by: twilight+princess
Re: New remote
We're just fellow customers here so you'll need to call Sky - either 150 from a Sky phone line/mobile or click on the contact us link at the end of the page.
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
Re: New remote
Hi @theglovers
To contact Sky
Avatar for theglovers
Re: New remote
Thanks for link worked great thanks
