Discussion topic: New broadband mini box issues
This message was authored by: Reprhi
We've had a new broadband provider set up details on the main box. Mini box has lost connection. Thought it was remote issues but did re set & got qbox to re connect but to main box but now getting ME102 issues but I can't get onto setting on the mini box to enter new broadband details on there?!
Re: New broadband mini box issues
Hi @Reprhi
If you are on 3rd party (non Sky ) then your minis can only connect to the main Q box or a Sky Q booster.  So there are no Network details that you can enter into a mini.
Reboot the mini as above.
Avatar for Reprhi
Brilliant thanks all done
