Discussion topic: New Sky viewing card not working
Message posted on 11 Jul 2026 02:05 PM
I have a new SkyQ box and Sky viewing card and keep getting this error message- Your viewing card is no longer active. If you have requested a replacement viewing card, please insert your new viewing card as soon as it arrives
I have pared the card and connected to WiFi. Rebooted several times- still not working
Message posted on 11 Jul 2026 02:45 PM - last edited: 11 Jul 2026 02:46 PM
Re: New Sky viewing card not working
The installer should have had it working before they left.
I think some old Sky cards do not work in SkyQ boxes.
Have you done the card pairing? It is in the Services -> Setup menu.
@MM1112 wrote:I have a new SkyQ box and Sky viewing card and keep getting this error message- Your viewing card is no longer active. If you have requested a replacement viewing card, please insert your new viewing card as soon as it arrives
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
Message posted on 12 Jul 2026 09:42 AM
the card pairing will not work with that card, he need s an new card, i had that Problem as well.
I got a new one, and that was working and could paired.
Message posted on 11 Aug 2026 12:06 PM
Will I need a new viewing card for my sky box? Can you send me a new card.
Thank you for your support.
Message posted on 11 Aug 2026 12:11 PM
@Skymatt wrote:Will I need a new viewing card for my sky box? Can you send me a new card.
Do you need a new viewing card? Is your current one working?
Message posted on 11 Aug 2026 12:17 PM
Please can you send me a new viewing card. It says I need a Correct viewing card with chip and pin .
Thank you
Message posted on 11 Aug 2026 12:39 PM
Thank you
We can't because this is primarily a customer to customer help forum. We have no idea who you are or where you live.
If you need a new viewing card then you need to call Sky.
