This discussion topic has been answered Discussion topic: New Sky Q remote won’t setup
Message posted on 07 Oct 2024 12:01 PM
Been staring at this intermittently for an hour! New remote just been delivered as old one stopped working, remote controls sky box while pointed at it but it won't work on Bluetooth and can't get through setup.
Message posted on 07 Oct 2024 01:38 PM
Hi @Tam211
First try rebooting your Q box?
Then
Hi @Tam211
Then
