Discussion topic: New Sky Q box no apps, help request ASAP
This message was authored by: MG57
Hello
Got the Sky Q box yesterday plus superfast internet
Everything appears to be working on the Sky Q box but no apps other than 2 Peacock
I've rang Sky technical and the software was updated from the first lot to Q220 or something like that. I did this with the help of Sky staff last night about 20-00hrs.
This morning no new apps, all missing other than Peacock
I unpluge the router, did not do the trick. I unplugged the Sky Q box, did not do the trick
I went on the web and refreshed the apps but initially typed into the remote 0-0-1 then SELECT - this was over 45 mins ago. No success
Please help and thank you in advance
Avatar for MG57
Level 2 icon
Re: New Sky Q box no apps, help request ASAP
Resolved.
I rang Sky again and it was something they needed to action again from their end, Got all the apps now.
Hope the above helps
