Discussion topic: New Sky Q box installed , picture now jumping and pixelating
Message posted on 06 Jul 2024 08:12 PM
Had replacement Sky Q box installed. Picture now jumping and pixelating. Did a software update on all Sky boxes but did not resolve issue. Any ideas? Thanks
Message posted on 06 Jul 2024 08:27 PM
Re: New Sky Q box installed , picture now jumping and pixelating
Hi @Steviet27
