Discussion topic: New Q box
This message was authored by: 1368ag
New Q box
Hi I'm having a new Qbox delivered tomorrow as my original box is faulty, will I be able to retain recordings from my original box?
This message was authored by: Jones_The_Cat
Re: New Q box
No. Your recordings will be gone. Make a note of them before you remove the box before the swap and you can hopefully re-download them from on demand.
Remember to remove your viewing card from the old box before handing it over to the courier. Also make sure you give them the power cable and remote and make sure you get new ones in exchange. There are different types of Q box, some with different incompatible power supplies.
Avatar for 1368ag
Re: New Q box
Ok will do, thanks for your response
