Discussion topic: Network dropout
Message posted on 28 Mar 2025 01:09 PM
Network dropout
- I have an LG Television
- I have Sky Q
- I have an EE Router with non wired Ethernet connection
- I keep losing the Network connection and thereby lose catch up tv, films etc.
- If I switch off the power at the wall, wait 2 minutes, switch back on, then everyhing works perfectly for a limited time of around 9 hours before the Network connection is lost.
- I then can reinstate the EE router password or switch off at the wall and go through the whole process again.
- What is the permanent solution?
Message posted on 28 Mar 2025 01:24 PM - last edited: 28 Mar 2025 01:24 PM
Re: Network dropout
@neil+payne1 wrote:What is the permanent solution?
Use Ethernet cable.
Message posted on 09 Apr 2025 02:05 PM
Re: Network dropout
With reference to Wired Ethernet: It would be impractical to have wired ethernet cables. My EE router runs without fail. The issue I believe is the Network between the TV and the Sky box. When I go to settings after the Network fails I get a checklist which tells me that the Internet connection/router is working as it should do but the Network connection has failed. I have tried to speak to a Sky engineer but I keep getting a recorded message. Please arrange for me to speak to an Engineer or give me the number. An Engineer would be able to solve this problem I'm sure.
Message posted on 09 Apr 2025 02:12 PM - last edited: 09 Apr 2025 02:14 PM
Re: Network dropout
Hi @neil+payne1 There is no network connection between the TV and Sky Q box. They are connected by HDMI cable. Note nobody can arrange for you to speak to an engineer on the back of a public community forum post. Telephone numbers are blocked in the community.
Message posted on 09 Apr 2025 05:27 PM
Re: Network dropout
Thank you MightyQuin,
Still have Network dropping out though but thanks for the info.
Regards, Neil
Message posted on 09 Apr 2025 09:56 PM
Re: Network dropout
Ethernet is, by definition, wired. I assume you mean non-wired network connection, or as the world generally refers to it, a Wi-Fi connection? They are notoriously unstable on Q with non-Sky routers.
You could try switching on the "2.4GHz compatibility" wifi mode that the modern EE routers offer, if it's one of those, and connect the Q to that.
