Discussion topic: Network connection
This message was authored by: Vinny6
Network connection
We can connect our sky q box to the sky broadband. We have tried all of the trouble shooting advice multiple times, but it still doesn't work
Re: Network connection
@Vinny6  have you tried resetting the network setting s within the Q box menu? https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-connectivity
Hi @Vinny6
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
