Discussion topic: Mini box has stopped working
This message was authored by: IAAC
we spoke to Sky yesterday about wi Fi issues. These issues weren't resolved fully, however now our mini box isn't working
Re: Mini box has stopped working
Hi @IAAC
Reboot the mini as above.
