Discussion topic: Network connection problem
Message posted on 04 Apr 2023 12:42 PM
Hi. Broadband is working fine but sky a boxes have network connection problems.
Message posted on 04 Apr 2023 12:45 PM
Re: Network connection problem
Hi @Jxs1204
Assume you have tried a Network reset on your main Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
