Discussion topic: Network connection not working firctv
Message posted on 14 Nov 2023 03:23 PM
Message posted on 14 Nov 2023 05:33 PM
Re: Network connection not working firctv
@Philippa666 wrote:
Is this your main Q not connecting @Philippa666
If this is the issue
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
