Discussion topic: Network Problem
This message was authored by: JG281
Network Problem
My Internet is working on every device in my home including my main Sky Q box. The mini is not connecting.
I have reactivated the box numerous times, switched both boxes off, reset them, reset my Internet, you name it and it won't work.
Everything has worked perfectly for months, even years and now all of a sudden the mini won't connect.
If I reset the internet on, it perfectly finds the wifi, connects then stops after a minute. It's highly annoying.
This message was authored by: Beasch75
Re: Network Problem
The same is happening to me. So frustrating. Hope you get an answer
Avatar for JG281
Re: Network Problem
If I get to the solution, I'll let you know!
Re: Network Problem
@JG281 who is your broadband provider ?
if its not Sky then your mini boxes don't connect to your home wifi they connect to the main box by way of a Sky mesh when you reset the boxes you should get a message about pressing the wps button on the nearest piece of Q equipment which would normally mean your main Q box but could be a second mini box if you have one
If Sky is your broadmand provider then the mini boxes do connect to your home wifi
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
