Discussion topic: Netflix
This message was authored by: Andy464
Netflix
Netflix will not open on main q box but will open on mini box. Tried the usual things, spoke to sky who went through the same things . Advisor escalated to tech team. Promised they would have it working within 24 hrs. Are there any other things I can do
Re: Netflix
Hi @Andy464
Have you tried refreshing the Apps in the main Q box Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
Avatar for Andy464
Re: Netflix
I've tried refreshing apps. Have just received a email saying they are going to delink my Netflix account any idea what that means. Thanks
Avatar for Andy464
Re: Netflix
I've done all the trouble shooting , but still getting the error code tv- on-101. Netflix works on the mini box
