Discussion topic: Netflix
This message was authored by: Boobooee
Netflix
I have Netflix through Sky, how can I login in to Netflix via app on another TV/device?
many thx in advance
Re: Netflix
Did you have to create a password when you activated netflix (I think it uses your SkyID email address) on your Q?
I'm still using a. Netflix direct contract so never had to do that and Sky's help page doesn't explain the process, just says "follow the on-screen prompts"
I've seen another thread that says you have to sign in your SkyID password too but I can't see that working unless netflix is clever enough to recognise the email is a sky based account and hand off the authentication to Sky in the background (which is technically possible but the other apps on Q don't work like that)
Re: Netflix
many thx in advance
Hi @Boobooee
The Get help in your Q Netflix menu will show you the Email you use for Netflix.
Then go to the following link to setup a password.
https://help.netflix.com/en/node/365
Even if you have not set a Password you can still set one up in the change password link
Dot forget that you are limited to the number of screens in simultaneous use
